Table 1. Egress Tunnel Shaping product support
Feature
Product
Release introduced
Egress Shaper for Fabric Extend tunnels on Fabric IPsec Gateway virtual machine
5320 Series
Not Supported
5420 Series
Not Supported
5520 Series
Not Supported
5720 Series
Fabric Engine 8.7
Supported on 5720-24MXW and 5720-48MXW
7520 Series
Fabric Engine 8.10
7720 Series
Fabric Engine 8.10
VSP 4900 Series
VOSS 8.3.1
Supported on VSP4900-12MXU-12XE and VSP4900-24XE
VSP 7400 Series
VOSS 8.3.1
You can configure the egress shaping rate to limit egress bandwidth for tunnels on the Fabric IPsec Gateway Virtual Machine (VM).
Egress Tunnel Shaping shapes unicast, multicast, and unknown unicast egress traffic on the tunnel.
Eight traffic queues are created for the tunnel traffic when a new shaper is configured. Packets are mapped to any of these queues based on the internal Class of Service (CoS) of the packets. When multiple tunnels use the common shaper value, an internally unique shaper is associated for each tunnel. The following table shows the default minimum weight for each queue.
Table 2. Default minimum weight
Queue Default minimum weight
0
5
1
20
2
30
3
40
4
50
5
50
6
Rate limited to 50% of configured shaper rate
7
Rate limited to 5% of configured shaper rate
Queues 6 and 7 are rate limited and have a higher priority. The maximum traffic allowed out of queue 6 and queue 7 would be shape rate/2 (50% bandwidth) and shape rate/20 (5% bandwidth).
Consider the following when you configure the egress shaper rate:
